The wires are part of the coil , you would have to replace the coil to get new wires. A common problem is bad spark plug caps. Just unscrew them from the end of the wire and put new 5000 ohm caps on.You can use an NGK LBO5EZ Should only cost about 10 bucks for the pair. If you need to replace your coil you will want to put new caps on anyway, just try them first.
