the hardest thing may be getting the pump loose from the hull. you will need a impeller tool to remove the impeller or an old drive shaft. if you get it out you need to cut the wear ring in 2 places to pry it out, then you can drive the new ring back in. dont forget to put pump oil back in and check the oring.
