I have a 94 750 ST.
Got it last year, cleaned up the stator and it ran fine.
Let some friends use it and it got filled with water, not sure why, i' would have thought it would have a build in pump, but not sure???
Anyhow, now the problem is that at full throttle the machine just revs up and goes nowhere. At half throttle and lower it drives, but as soon as u hit it its got nothing. My question is, is there a clutch? I asked a around and somebody said they have impeller thrust bearings which is what is blown. Is this true? I checked the impeller with my hand and it seemed intact and not missing any fins or bent, and nothing was clogged in it.
Also, if this jet ski has a pump, does it pump water out the little black nozzle located on the right side near the front? The first time I ran this machine it shot water out of there, but now it doesnt. If that is the pump outlet, how do I go about accessing the pump and testing it?
Any help would be greatly appreciated, and if it is the thrust bearing does anybody have one they could sell?
Thanks
Thanks
