1994 750 Super Sport Xi
Compression test: 155/155
The thing has sat in a barn for over a year. The carbs were gummed up, but they have been cleaned. Fuel tank hadn't been emptied, and new fuel was added. I syphoned out as much as I could, ~5 gal, and added 2 gallons of fresh. Starts almost instantly.
Runs great out of water. When it's in water, the only way to keep it running is by having the choke on all the way. Where should I check for a restriction? The bowl thing is empty (I assume that's normal since the tank hasn't been filled in a while).
Where is the fuel filter, if there is one?
If the fuel is geled, will adding sta-bil help?
How do I test the fuel pressure?
