I was wondering if anyone could help me out im a newbie to the whole stand up jet skis. I got a 94 750 sx, out of water it runs mint revs out and only problem is it rolls over alot to start and seems when you let off the start button it fires like its gunna start. It wont fire right back up after running it. The main problem is soon as i put it in water it wont idle and wont pick up and go under load. if you keep it at an idle to quarter throttle it will go on plane but soon as you put it past quarter throttle it boggs out, and if you get it leaned over in a corner or hooping out of the water it will rev out fine . It seems to rarely ever start while its in water you gotta lean it over or hold the back out of the water.It also has a new battery. if anyone know anything that can help me out id appreciate it.
thanks
thanks
