I don't recall ever using silicone to glue that wedge/scoop in
place. MarineTex is better suited for the job. And yes there
were problems with cavitation and that pump. You can try
applying a small bead of a high quality (low shrinkage) clear
silicone, ultra silicone onto the rubber pump gasket.
Is the rubber pump gasket missing?
Is it an oem impeller? Kawasaki used some horrible impellers
on the SS & Xi. A Skat trak or Solas impeller for a Stock Engine
is the best replacement.
Bill M.
Be sure to allow the silicone to dry for at least 48hrs before
you ride it.
Bill M.
you ride it.
