Hi i have a 94 slt750 that ran perfect until i broke the steering cable then it sat for a couple months... got the steering cable fixed now it has no power slowly gets up to about 25-30 mph... It runs and idles out of the water but revs way up then dies after awhile. It cant be much it took off in the water like its suppose to a couple times then bogs back down... ive noticed the center carb dumping fuel and the two outside carbs barely givin it fuel at idle is that normal?? Center spark plug clean like too clean but has good spark other two a little black not bad... any suggestions id appreciate it thanks
