My problem is under a hose it runs fine, pumping water out the sides as it should as well as in water. lines are all cleared, good compression but once in the water for 5 minutes or less it gets hot and will only idle. At times just idling it will gain speed again for about a minute and back down to shutting off, restarting and does not won't to go any faster than idle. It did run one day for 30 minutes fine, then take it back out and it does same thing. Would appreciate it if you could directly help me with any help.
[email protected]
Thanks
Joe
[email protected]
Thanks
Joe
