I don't know about that specific ski, but the "visibility spout" as Yamaha calls it, is usually fed from a rubber hose from the pump to a little fitting under the spout hole. I suspect that your hose has come loose or off. Look directly under where the hole is that the water usually comes out of and then see if you can find a hose hanging loose on the back of the ski around the pump/nozzle area.
It want hurt anything to leave it off...........in fact many people get tired of the spout and disconnect it anyhow.
