Looking for some direction on this one. We have a 1996 Sea Doo GTI with less than 100 hours. Used very little as can be seen from the hours and it has never been in the shop except for the fuel tank recall.
After running some 8 miles without any issues, I stopped at the local marina and filled up with gas. Then the trouble began. GTI would not start and acted as if flooded. (Normally it fires up immediately) Finally after 10 minutes of cranking, it fired but with a lot of blue smoke from the exaust. Once it seemed like the flooding cleared, there was very little power to the unit. But then it came up to speed and we were off. Like many people who have owned something for a while, I heard something in the engine compartment that did not sound right. Then the GTI started loosing thrust and with throttle almost wide open, we were going nowhere. Then the overheat light and buzzer started and I shut it down. And then the GTI started down. I flagged a boater and they came along side and we got onto their boat. Looked in the engine compartment and it had about 8inches of water.
Forgive the details, but trying to convey everything that happened and in sequence. Having not worked on this unit before, I assume there is a seal on the shaft that may have been breached and that is where the water came in, but wondering why the unit began over heating. I am hoping this may be limited to shaft, impellor, seal etc. and not engine related. If thrust was lost, would that cause the over heating? Any advise would be appreciated whether I tackle this or move to a dealer. GTI is on a lift and not yet on the trailer, so I have not looked underneather or had a good look at the empellor/shaft area. Thanks...
