Hey guys - I am a newbie to this site - I have a 96 GTX - that stalls when full throttle is applied - can and will run if anything less then half throttle is applied - have torn apart the carb - had it acid bathed - so all ports are clean - have taken out and cleaned out the gas tank - blew out all lines - ensured the shutoff valve works - what am i missing???
when it does stall - you then need to choke it to get it started - any help /advice would be greatly appreciated - can one of the gas lines be collaspiing - i had a similiar issue with my boat coming out of the hole and it turned to be my gas bulb in the fuel line.
