I had some bogging in the low end RPM range between 2000-3000 RPMS. I decided to pull the carbs and clean and inspect them for trash and worn diaphrams. I cleaned them and put them back on and adjusted them per Mikuni's factory settings and still have low end bogging. It does scream above 4000 rpms and now runs up to 6000 rpms whereas before it would only turn 5500.
It has new plugs, runs premix and compression is @ 175 per cylinder.
All filters are clean and have been checked.
Any ideas from you Pro's out there? Thanks for any suggestions !
