96 gtx huh? Same exact ski as mine i had this same exact problem too a couples years ago. Be sure the connector on the wire to the temp sensor is tight its in a place where it always gets bumped and the connector kind of bent to where it wasnt making a connection with the sensor. I just took a pliers and bent the connector tight and it has worked fine since then.
