I recently purchased a jet ski, it is a 1996 SeaDoo SPX all stock with a Rotax 717. I took it out in the water today and it was running fine, felt like it was missing some top end acceleration. After riding for about 20 minutes I pulled it up onto the beach. I sit for a minute, then it started to make this extremely loud, obnoxious, ear piercing alarm noise. The speaker that it came from is under the handlebars. I couldn't get it to stop so i had to ride it back home and disconnect the battery.
Any ideas why it is doing this and wont stop? how can I fix it?
Another issue is that it was missing a little bit of low end power and a lot of high end. After riding for a little bit it lost a ton of low end and basically I was stuck putting around at 20mph on and off. Could the carb not be tuned correctly? Maybe spark plugs? Also, What spark plugs does this take?
And last but not least, im not sure that the Variable Trim System is working correctly, is this an important feature or can i do away with it?
Thanks. Any feedback will be appreciated.
