I have a 96 SPX. I have an occasional issue with this PWC.
When you open the throttle it will only reach about 4000 RPM. You can then choke the engine and it dies.(as it should). You can then restart the PWC and you will get full throttle. (sometimes it takes more than one time to get the problem corrected). The PWC will then run most of the day with no issues.
I have replaced the fuel valves and almost all of the fuel lines, the only lines not replaced are the breather lines.
Any ideas?
Any ideas?
