starter spins but is not engaging the fly wheel. just put in a new starter and still same problem.could be the bendix but could it also be a solenoid or something else? i took the cover off the flywheel and saw a small gear shaft that the starter engages to turn the crank but that seems ok.maybe a silly question but should the shaft on the starter kick out like an automotive?will get it tested tomorrow.it seems like it should but any insight is helpful and thanks
thanks Ernest.Even on a new starter?I know they can be defective, but is the shaft supposed to kick out to engage ?Had it tested and the shaft on the starter is not kicking out. Defective starter?
