Hey i have a 1996 yamaha wave runner 1100 3 cylinder that has low hours a little over 100 hours, and the battery has quit charging, i have the same voltage before starting as i do when running, even when i rev it up same voltage, i have looked for loose grounds but cannot find them, i removed the big intake manifold to gain access to be able to see more and the covers from the carbs but cannot see anything. My local dealer said it could be one of 2 things, but it most likely is loose grounds since these take a beating when ridding, my brother has the same jetski that has over 500 hours on it and he has had loose grounds 2 seperate times when he took it in, can you help tell me where to look or what to check, thanks, Ben
