Im working on this for a friend. It seems to run fine off idle but if you let it idle down it dies unless you feather the throttle. Once it dies and I pulled the plugs all are wet with oil but no smell of fuel. they are also staying white so definately not rich. It has the three carbs on it with a pulse actuated fuel pump. Don't want to just start throwing money at it without an educated guess. You would think if the fuel pump was bad it would effect upper RPMs. I have already replaced the 3 needle and seats in the carbs. Any help is appreciated. thanks
