On mine, there is a shaft on the right side of the nozzle. It has a knuckle on one end attached to the jet nozzle and then a nut. The shaft is also threaded where the nut and knuckle are. I believe that is where you adjust it. You will also have a similar set up on top but that is for your trim.
