Does anybody know the hp on these?
They sound sweet
The world's first production turbocharged four-stroke, three-seat personal watercraft continues to dominate. And its features continue to impress; 1235cc turbocharged four-stroke engine, off-throttle steering system, selectable speed limiter and electronic keyless ignition.
Engine Type 1235cc liquid-cooled dry-sump inline four-cylinder with intercooled turbocharger
Bore and Stroke 79.0mm x 63.0mm
Compression Ratio 8.5:1
Valve Train DOHC; four valves per cylinder
Carburetion PGM-FI with automatic enricher circuit
Ignition Computer-controlled digital with three-dimensional mapping
Length 120.5 inches
Width 45.7 inches
Height 40.8 inches
Dry Weight 746 pounds
Fuel Capacity 16.6 gallons with low-fuel warning
Pump Axial-flow single-stage 155.0mm jet pump with reverse
Hull Fiberglass reinforced plastic (FRP) outer hull, inner hull and deck
Storage Capacity 5.8 gallons
Seat Length 33.1 inches
They sound sweet
Length 120.5 inches
Width 45.7 inches
Height 40.8 inches
