So i had some bad cavitation... replaced the impellar and housing and the "slipping transmission" feeling has been corrected unless i try to go from a stop to a full throttle
HOWEVER... after about 1.5 minutes of cruising at approx. 40 MPH, it just shuts off.
i thought my battery cable came loose and when i reached down to check, I got a lovely 3rd degree burn off the positive terminal. negative was luke warm, but positive had to be several hundred degrees.
what could cause the battery to do this??? bad battery? overcharged? it is a standard acid based battery.
