I was tapping the drilled starter bolts on my 92 waverunner and broke the tap off in one of the holes. I used a dremel tool to grind some of it out, is there a drill that will drill through the tap?
I've had success drilling out a broken tap using solid carbide drill bit. You can get one from industrial supplier for ~$20. If you have welder - do like the previous poster said - much easier.
