When my F-12X turns off, there is a buzzing noise at the rear of the ski somewhere below the rear fuse box. If unplug the red wire below the fuse box, the buzzing noise stops. When I insert the lanyard and after the LCD finishes its bootup dance, the buzzing stops immediately and the ski starts and runs fine. After shutting down the ski by removing the lanyard, when the LCD goes blank, the buzzing starts again.
The buzzing sounds like maybe a small motor running or a solenoid partially on.
For now, I am unplugging the red wire when the ski is not in use with no undesired effects.
Thanks,
Peter
Thanks,
Peter
