1992 Polaris SL650,
Carburetor is sticking.
When you push on throttle, and let go, the throttle does not spring back. lubicated throttle cable, its fine. I removed the cable from carbs linkage, found out its the shaft that runs threw to the carburetors is stiff, springs on shaft are ok. Cleaned with carb cleaner but still sticking. Whats my problem ?
