This VX110 I just bought came with too much oil in it. I want to check to see if I need to replace the air filter before I take it out on the water next season. Is it just those four screws that hold the air box on, or is it more complicated than that? Plus I'll have to get an angled screwdriver to get in there as well. Is this easy to do? I have the tech manual, but couldn't find detailed instructions on how to do it. Thanks.
Its not that hard, but awkward. Its been awhile since I helped my brother with his, but it seems like there are 5 or 6 screws to remove. You also need to remove a hose going to the engine, and pull a line out of the way so you can slide the top out.......may be the fuel line (you may need a helper to have enough hands). If you have the service manual it will show you where the screws/hoses are.
