ADK PWCer said:
He only wants $425 for it and I wouldn't use a whole lot. Just a toy, we have a bowrider that we would use most of the time.
well if its decent shape and you dont care how fast it goes, then thats a good buy..
does it come with a trailer?
i would check for oil in the hull.
compression, even if you dont know what it should be,all cylinders should be close to each other,, if they are thats a good sign.
first take the plugs out and spin the crank by hand to verify its not seized.
look inside the pump area for damage, bottom of hull for gouges,, rear of ski if you can access it to check on the rear exhaust components.....just use your best judgement...
if it talks like a duck,walks like a duck then its probably a duck,,so if it looks like shit and sounds like shit its probably,,, well you get the point...
good luck
