1 - 4 of 4 Posts
I have a 2008 GTi SE 155 with only 50 hours on it. The battery reads 13 volts but motor will not turn over enough to start. About 5 years ago, had a new starter put on and 2 years later had the start/stop button replaced. Have had cranking problems since it was 6 months old. Any ideas?
Super Moderator
Check and make sure all the battery cable connections are tight, clean, and the cables are good, especially the ground cable.
1 - 4 of 4 Posts
