i have a 2001 polaris genesis 1200 and im having so engine problems. i can start it up when it is cold and it will run for a little bit until i hit the gas and then let off and then it dies. i pulled the plugs and they were all wet so i changed them out because i thought they might be on the way to fouling out. after i changed them it started right up and did the same thing. i pulled the plugs again and they were all wet agian. Have any ideas? maybe i need to rebuild the carbs? adjust something? what do you think?
