My F12 blew a piston out the side of the crankcase so I was thinking I‘d just rebuild it replacing the damaged parts. In my search I found a used 2002 F12x engine. I was wondering if I could strip the exterior components off of the F12x engine and use my F12 intake, exhaust, etc. to set it up as a standard F12. Will this work or are the internal components (pistons, valves, tolerences, etc.) different to the point it won’t function naturally aspirated. Thanks for your help.
