1 - 19 of 19 Posts
On my 2001 800XL, the tops of the carbs and choke plates are wide open and visible which it looks like would make it really easy to splash water into them if there is any water in the hull. Am I missing some sort of cover for the carbs?
Can someone help me out with a part number or exact name for what I am missing? I am having trouble finding it...
Here's what I found on eBay. item # 401551905419. $23.94, free shipping. Redline motorsports. It looks like it may be missing the flame arrester screen and mount bolts. If you contact him, he may be able to add them. If not, it's still available from "Babbittsonline" as for bolts. there 6mm you just need to figure length, and I'd use stainless if you can. Plus you'll need new seals for it. They are actually just a set of O rings.
Hope this helps.
The easiest way I've found to find parts for these old beasts. Is to look up the factory part # on Babbittsonline. Then serch it on eBay as "Yamaha" then add part # and then sometimes the description. In your case I serched. "Yamaha 66E-14480-19-00 air box"
Discussion Starter #15
90105-08M86-00
Is that the part number for the bolts that hold this to the carbs? I also see I failed to order the O rings...
90105-08M86-00
The part # I find on Babbittsonline is 97013-06045-00 for the bolt. And 92990-06600-00 for the washer.
The oring gasket is best found at SBT part # 41-406-23
Discussion Starter #17
Looked like those were the screen bolts...hard to tell by the pic if you aren't familiar with the actual parts.
Thanks again for the help!
1 - 19 of 19 Posts
