I have looked inside all the exhaust piping that has a water jacket and do not see any place it is innerconnected. If all the gaskets are good it seems you should be able to connect a hose and run water thru the cooling system with the motor off. Is this the case? If not can someone explain how water can fill the case if flushed with the motor not running.
