I have two 2000 Yamaha XL1200LTD. Twice now, both my skis would idle fine, and run fine on the hose. But on the water, once you hit the throttle, they would not go above 10 mph and eventually die.
So I did what I could from draining the fuel tank (thought there was water in the tank), to change spark plugs, batteries, compression tests, and add Sea Foam. Nothing worked until I changed the little in-line fuel filter (sits just under the handle bars).
So when it was happening the second time, I replaced the fuel filter and everything was fine.
My question is.....could it really be this simple? And how can I prevent this in the future? There is no way I should be replacing filters every 20 hours? Is anyone using a filter other than the stock Yamaha ones?
And I am using medium grade gasoline on my stock oil injection skis. I was using low and high grade to test but nothing really seemed to matter. Also got gas from different stations to rule out that factor.
I appreciate any help. Jim
