1 - 4 of 4 Posts
Im putting a motor and jet drive from a 96 Tigershark 640 in a small aluminum boat, my plan was to use a small gas tank but it only has an outlet, what do I need to do with the return line from the carb? Also can I delete the oil injection and just mix the gas and oil?
Premium Member
Fuel tank has to have a return line. The oil injection system can be deleted IF it does not feed any crank bearings or balance shafts, basically if it ONLY feeds oil to the carbs. The systems are very reliable and usually way outlive the engines when maintained.
1 - 4 of 4 Posts
