After towing our 2007 FX HO out to the river, I could not get it over 45 mph. It acts like it is in "Learning Mode" in that the power is smooth and the engine sounds like it's running well, but it simply doesn't have the power or speed that it should. Using the remote, I set it to "lock" then put it back into "unlock" mode. Two beeps from the unit are supposed to mean it is in normal operation mode.
The manual says you can tow the unit with another boat as long as it doesn't exceed 5 MPH. We towed it to the river with our pontoon boat, which did not exceed this limit.
No water in the hull, nothing covering the intake grates.
Last use was two weeks ago and all was normal. Any thoughts?
