I am deleting my oil pump and lines, and switching to pre-mix.
The ski in question is a 2000 XL800. Over on PWCToday.com they list different pre-mix ratios that are supposed to match what the stock oil pump puts out at wide open throttle. For the 800/1200 they say to mix it at 32:1.
Anyone out there with an 800/1200 running pre-mix? What ratio are you mixing at?
What oil should i be using to ensure above adequate lubrication?
What about break in, any special oil, or just mix it a little richer?
