Hey, put in some new plugs, launched ski, started right up, screaming right along for 10-15 minutes...shut off for a couple minutes. When I went to go, bogged right down...ran around on what felt like 2 cylinders for 10-15 minutes, pulled to shore, took off seat...the aftmost cylinder was definately cooler than the other 2....pulled plug, it was soaked...pulled the other 2, they were hot and dry...so my question to you is, is it possible the carb was dumping to much fuel causing that cylinder to flood? or is the ecm(or whatever the "brain" box is called) warming up and cutting off power to spark plug causing fuel to be unburned? thanks for any help!!!
