Thanks for the info-
Maybe you can help with this aswell- sometimes the exhaust get very hot, seems like its blocked sometimes with debres or sand etc- when I flush it outside the water the water dont come out of the small round hole under the rear step just next to the exhaust hole- how can I clean or open the watercooling system so that it :unblocks" quicker maybe-
Yes, what year is the GPR? Reason I ask is because when they get older the catalytic converter in the exhaust likes to break up in pieces and clog the exhaust. It happened on my GPR. If this is your problem you have two solutions:
1) Replace the cat with a good used one (unless you can afford to pay something like $1500 for a new one from Yamaha.)
2) Remove the cat and install what they call a "D plate" in place of the converter. Alongside with a special electrical plug that connects to the exhaust temp sensor that tricks the computer into thinking you still have a cat and all is well so you won't get the exhaust temp light.
There is a wealth of info on the internet about this issue. Replacing the cat has the advantage of 50 RPMs higher redline. When you install the D plate because of a drop in back pressure you lose 50 rpm off your redline. The D plate has the advantage of added reliability since there is no more cat to fail and a little weight savings since those things weigh a good 15 pounds or so. Best of luck.
