My 96 gsx runs great and starts right up when I take it off the trailer. But after running awhile and shutting it off its hard to start back up. It will start but dies when you give it throttle. You have to feather the throttle or a little not full choke, but once it does get running it runs great until you shut it off. If you try to start it right back up its fine but if it sits for a few minutes or longer the problem is back. It has the 787/800 engine and the fuel lines were replaced about 2 years ago and the carbs gone through by a local shop. Its runs great and has just started doing this the last time I took it out.
