Ok, I think this is a very weird problem and I will do my best to explain it so bare with me.
I have an 89 Seadoo and the first time I took it out after getting a tune up from the local dealer it took a good 10minutes to fire up. Once it started it would die, this went on for a few minutes. Finally it fired up and stayed running the rest of the day with Zero problems. After initially putting the ski in the water it was turned on and off a dozen times the rest of the day and it ran great.
I put it in the water a few weeks later and it fired right up withing 10 seconds, no problems.
The third time I put it in the water I noticed I was low on gas so I went to get the gas cap off and it was "stuck". I had to use the soft end of a screwdriver and a hammer to get the cap to turn and come off. I didn't think much of this and I filled up the ski with 91octante gas. Well, when I got to the river and went to fire it up it would not turn over at all. I tried for a good 10-15 minutes and the ski would crank just fine but it never even sounded like it was going to attempt to start.
Im not mechanically inclined but this is just a guess.
It seems odd that I had trouble the first time when I took the gas cap off and put gas in. The 2nd time I put it in the water I didnt take the gas cap off and it fired right up within 10secodns. The third time I went to use it AFTER taking the gas cap off it didnt fire.
Could I have some sort of vapor lock going on????
The dealer said they didnt have any problems with the ski during their test ride, I plan on taking it back there in a few days but what could be going on here? The ski orgianlly had fuel delivery problems and the dealer replaced all the fuel lines and did a carb kit to it (and new battery)
