bought this thing not running, cleaned carbs drained water out of gas tank and thoroughly dried, changed fuel filter, dumped gas in carbs and ran great, put fresh gas in tank and ran great, for a few days, eventually seemed to start bogging, pulled fuel tank due to suspected leak, found no leak, but had water in the gas and fuel in hull, put back together and ran for 5min, then bogged down and would never run right again, i rechecked compression which had been 145/150 and now it was 30/150, what could have caused this? there seems to b alot of moisture in cylinders, and more fuel in bilge! any ideas, trying to figure out if i should part it out or fix! thanks
