I have a 2002 Yamaha 800 XLT. Just replaced two the two piston and a cylinder. The power valve that is attached to the cylinder has a bolt that will not lock down tight to the cylinder and I can see it spitting fluid thru it. I assume this is what is causing my engine not to stay cranked and rough idleing. Does anyone know what this loose valve would cause?? Thanks in advance
