I posted a thread a few days ago and only got 1 reply. Iwould like info on where to buy parts and what brand. I smoked the # 3 piston I also found some oil in the hull so I'm assuming there is a oil pump or oil line issue. My plans are to rebuild the top end and block off the pump and go pre-mix. I will also go thru the carbs. When I get the carbs off for re-build should I replace the reeds? On the performance side are there any good upgrades that I should look at? The boat is a 96 Wave Venture with under 200 hours that other than the engine problem is in excellent condition. Thanks in advance!:appl:
