Any ideas will be greatly appreciated...We have a 96 Sea Doo that we had to have the prop replaced because of a chuck missing out of it. After replacing the prop with what we thought is the correct part...If going full throttle the jet ski will loose RMPs for a few seconds and then its fine....It will repeatedly do this over and over....usually if going over 5000 RPMs...Any ideas or suggestions on what this might be....It never had done this before....We dont use it very often but it is always properly maintained and has around 100 hours on it....Thanks for all you help...
