Hi All,
I am in the uk and have a 1998 TS-L1000. I have got the thing running fine but the water cooling system does not work.
I have checked the filter and used the links in this forum to try and follow the line through with the online parts catolouges but I can not find the pump / impeller for the water cooling system.
When I use the above the cooling line goes into the Magneto case and then dissapears no sign of a pump!
Can any one help point me in the right direction or even let me know if the engine has to come out to overhaul the water pump or not.
Any help would be really appreciated as trying to get out on the water and the hot summer days are few and far between over here.
Cheers.
Cheers.
