I am here becuase i purchased a ts650 yamaha 1992, everything in it looks very well, and starts and runs when prime, but a minute later dies, and would not restart, unless a prime it again, i have change the carb seals and clean it, unfoutunately i did not do the ultrasonic clean, but the seals and carb looked alomost new, I still cannot make it run for 5 minutes if I dont prime gas into the carburator. battery is new and cranks good, gas is the top 91 with seafoam, if i dont hear any help I would have to take it to the dealer. cheers!!!
First off, did the ski come with the primer or is it aftermarket? If its aftermarket you might want to try removing it. Make sure the fuel filter isn't clogged. Did you replace the diaphragms in the carb?
