1 - 4 of 4 Posts
Ok my jet ski has carb problems, i need to be able to run this out of the water but i cannot figure out how to hook up water to it. Its a 1995 wave venture with the wvt700 t motor
If you don't see a hose adapter, then one may not have been installed yet. There should be a screw on the rear of the engine that you remove to install a flush adapter kit. It should be in the owners manual. Most of the 700 motors had the flush port at the rear of the engine. Here is an idea where to look from a 650:
1 - 4 of 4 Posts
