How to remove the prop or impeller 93 tiger shark 640
1185 Views 7 Replies 2 Participants Last post by  Greasemonkey
Hello everyone I’m having issues with removing the impeller on the jetski I’ve tried everything. Ive put my hilti 1/2inch impact on it with a lil heat, also with a wrench and 2x6 holding the shaft. Ive even leaned into it with a breaker bar….. nothing. Am I missing something???
Wood Automotive tire Camera lens Grey Cameras & optics
See less See more
1 - 8 of 8 Posts
This step is directly out of service manual for early sharks with the steel jetpump housing. Hope it helps.
Font Newspaper Paper Publication Paper product
See less See more
It does help alittle the thing is still seized on there also quick question since you have a service manual what goes on the fitting here ? I found this vac hose by it not hooked up
See less See more
GOOD NEWS!! I put my body weight on it and got it off!! So do you also have the diagram of how the shaft is setup? Had some rubber debris in behind the impeller wondering the setup thanks for the help!!
Atta boy! Good to hear. Here is a pic of the top of jethousing from my 93 daytona. You will see the bladder which is to displace the air pressure in the jethousing so it doesn’t put pressure on the seals and cause them to fail/leak once you start creeping into the higher rpm’s there is also one located under the starter for same purpose in the stator/magneto housing.
Hood Motor vehicle Automotive tire Gas Automotive exterior
See less See more
  • Like
Reactions: 1
2
These pics follow the steps after the ones i sent for impeller removal.
Photograph Camera lens Motor vehicle Font Camera
Style Font Black-and-white Elbow Monochrome photography
See less See more
Before i forget. Keep in mind that nipple on top of jethousing once you remove it that is where you add 6 fluid ounces of jetdrive oil (lower unit gearlube for outboards works also) i personally use syncromesh transmission fluid that i use in my gmc canyon transfercase. Don’t completely fill it! The drain for it is a phillips screw on underside looking through intake grate right below the nipple fitting.
  • Like
Reactions: 1
1 - 8 of 8 Posts
