I had to rewire the ground in my e-box, replaice my wiring harness from the e-box to the stator assy, and I had to replaice the exciting coil and the charginc coil on my 88 JS 550
I have the e-box side of the wiring harness hooked up but I need help on the stator side.
I need someone to take a pic of there stator assy showing in detail how the wires are hooked up or if you have a manual if you can scan or take a pic of the page/pages showing in detail the diagram or picture of how the wiring is supposed to be hooked up.
I am guessing that the red wire on the pulsing coil goes to the red wire on the harnes
the grey wire on the pulsing coil and the grey wire on the harness go to the loop on the back of the exciting coil
the black wire on the harness screws down to the stator plate
the two green wires on the harness go to the two wires on the charging coil
is this correct?
and if so does it matter which wires on the charging coil get hooked up to the green wires on the wiring harness?
this is all I need to knwo and sadly no matter where you look online there is nothing revealing the anwser.
thanks in advance
is this correct?
thanks in advance
