I tried to rebuild a mikuni sbn44 on a 92 waverunner 111. Upon first install (after first attempt at carb rebuild) i had no vacuum. Went over the blow up schematic and noticed I didnt put the checkvalves in with the stripe pointing up. I installed a new jet (the one with the removable seat) and corrected the checkvalves, reinstalled and same thing. The rebuild kit had the fuel pump diaphrams which I installed as well. The ski has pretty good compression 135lbs. both plugs. There is a decent pulse. No I did not put the hoses back wrong. Pulse to the block, upper to the supply , lower to the return. I used an external tank which removes all the fuel lines from the equation and still the same thing.
I believe it still has to be the carb (fuel pump) but this schematic does not look that complicated. Most of the fuel pump gaskets and diaphram look to only go together one way. I can spring for a new carb but damn do I feel stupid. Has anyone here had the same prob before? I also got a primer ball and it fills the filter (new) and the ski runs until the filter is dry. No vacuum. Thanks for your help.
