Help?
I have a 1997 Yamaha Waveraider 700 that I have replaced the impeller on, I have removed the pump took it to a local shop and had them swap the impeller as I didn't have the driveshaft holding tool. I went back out into the garage this morning to reassemble and realized the shaft only turns 180 degrees before stopping, is this normal? I don't want to put it back in the ski only to take it out again. Is it possible that the shop tightened the impeller down too much? The shop doesn't open until three any other way to loosen it up without the proper tool?
Thanks,
Eric
